ACER Aspire Ryzen 5 4500U Big Sur (Successful Installation)
MrRush
AMD RYZEN5
Acer Aspire Ryzen 5 4500U comes with 8 RAM. VRam is normally 512mb. Lagging occurs with standard equipment. There is no VRam setting in the BIOS.
Additional RAM reinforcement was made. According to the video, VRam size was set to 2gb.
EFI required to increase VRam: GitHub - DavidS95/Smokeless_UMAF
Track Pad is working
Graphics card is working
Sleep Mode is working
Sound is working
Bluetooth works
USB Ports works
Internal Wifi does not support, problem solved with TP link tlwn823n adapter. Driver connection: Release Wireless USB Adapter-V14 ยท chris1111/Wireless-USB-Adapter (SIP must be disabled before installation)
Before installation, the installation is made with Whatevergreen.kext in the EFI file. After installation, Whatevergreen.kext is disabled and NootedReD.kext is enabled. Once the installation is finished, use the Post-Installation EFI file.
Pre-Installation EFI:
Post-Installation EFI:
