9800X3D and Gigabyte X870E AORUS Elite WiFi7 on Sonoma Build
mrt360
13
9800x3d
Hi,
I'm working with Claude to try to build this:
CPU: AMD Ryzen 7 9800X3D
Motherboard: Gigabyte X870E AORUS Elite WiFi7 (ATX, AM5)
GPU (temporary): XFX RX 570 4GB — in primary PCIe x16 slot for build phase
GPU1 (gaming): ZOTAC RTX 5090 SOLID 32GB — removed during build phase, needs SSDT to hide from macOS laterGPU (macOS):
GPU2: PowerColor Red Devil RX 6900 XT 16GB (Device ID 0x73BF) — will go in AOOSTAR AG02 eGPU dock eventually
RAM: 2 x 48GB DDR5 Corsair Vengeance — not yet purchased
Case: be quiet! Dark Base Pro 900 v1
PSU: Corsair HXi 1200W ATX 3.0
I'm not very far in to be honest. It's hanging at the place shown in the attached photo when booting from the USB. I haven't yet reached the start point of the install. I've attached the EFI here.
I've tried:
  • SetupVirtualMap → false (AM5 requirement per mikigal README)
  • SecureBootModel → Disabled
  • DmgLoading → Any
  • AM5 PCI bus enumeration fix → enabled
  • DevirtualiseMmio → true then reverted to false
  • EnableWriteUnprotector → true
  • ProtectUefiServices → true
  • DisableIoMapper → true
  • csr-active-config → 03000000
  • boot-args additions: agdpmod=pikera, amfi_get_out_of_my_way=1, revpatch=sbvmm, npci=0x2000
  • Updated OpenCore from 1.0.4 to 1.0.7
  • Bypassed KVM, plugged keyboard directly
  • Tried USB 2.0 port
The installer was downloaded as version 19.8.42
Any ideas where I'm going wrong?
Thanks in advance!
    EFI.zip
You might want to have a look in the Success Stories forum, as there are some other AMD 800 Series systems that have been mentioned and are running macOS.
You may be able to see what is different in your setup compared to the other OC EFI’s.
Reactions: mrt360
@mrt360
your config.plist booter section isnt correct
You can avoid to declare a MMIO WHitelist if you enable also DisablevariableWrite quirk (not advised but possible to do )
I think you have also to add SSDT-Plug in your ACPI section
Reactions: mrt360
Thanks for the responses so far. I wanted to update the thread as the plan has changed significantly.
I've decided to abandon the eGPU approach after research suggested that USB4 eGPU on an AMD hackintosh is unreliable and largely unproven, particularly with the ASMedia USB4 controller on the X870E. Instead I'm going to mount both GPUs internally in a new case (Lian Li O11 Dynamic EVO XL) which has room for the 5090 and a second card simultaneously if I put the 5090 in an upright position at the front of the case.
Updated hardware plan:
GPU1 (gaming): ZOTAC RTX 5090 — primary PCIe x16 slot, hidden from macOS via SSDT
GPU2 (macOS): RX 6700 XT — secondary PCIe slot, native macOS support
Case: Lian Li O11 Dynamic EVO XL
PSU: be quiet! Dark Power Pro 13 1600W
Current boot issue:
For this initial build and testing phase I'm using an XFX RX 570 4GB as a temporary display GPU in the primary PCIe x16 slot — the 5090 and 6700 XT are not yet in the machine. I'm stuck at CoreAnalyticsHub start completed during the Sonoma installer boot and cannot reach the installer. I've attached the current EFI.
Based on forum feedback I'm planning to make the following changes to the config before the next boot attempt:
Fix booter section (SetupVirtualMap, DevirtualiseMmio, DisableVariableWrite)
Add SSDT-PLUG-ALT.aml
Add NVMeFix, AMFIPass, AMDRyzenCPUPowerManagement and SMCAMDProcessor kexts
Switch SMBIOS to MacPro7,1
Any feedback on whether this approach is correct for the X870E/9800X3D combination would be greatly appreciated.
The RX 6700 XT isn’t natively supported by macOS, you need to use NootRX.kext to have that card working in macOS.
You don’t need the AMDRyzenCPUPowerManagement and SMCAMDProcessor kexts when installing macOS. They are not essential to the system booting macOS, in fact they are more likely to cause unnecessary issues than they are to help matters.
No EFI attached to you previous post.
You should use Corpnewt’s SSDTTIME script to generate the SSDT’s required for your system, not rely on generic SSDT’s that may not fit correctly. This script works in Windows as well as macOS, so you can use it before you create the EFI folder.
You would be advised to generate a custom USB kext (UTBMap.kext), again in Windows, using USBToolBox Tool, so you have your USB ports active and available in the macOS installation process.
Thanks for the detailed information. I think I've added the EFI in my first post on Wednesday at 8.38pm GMT. Isn't it working for you? I'm away this weekend, but will resume efforts on Sunday, so any suggestions would be great.
Update — macOS Sonoma successfully installed!
After a lot of troubleshooting I've managed to get macOS Sonoma installed and booting. Here's what fixed the various issues for anyone who finds this thread in future:
Issue 1: EXITBS:START crashFixed by adjusting the Booter Quirks — specifically enabling DevirtualiseMmio and DisableVariableWrite, and fixing SetupVirtualMap.
Issue 2: CoreAnalyticsHub hangFixed by running SSDTTime to generate proper board-specific SSDTs (SSDT-PLUG-ALT, SSDT-HPET, SSDT-USBX, SSDT-USB-Reset) and updating the kexts to include NVMeFix and AMFIPass. Also switched SMBIOS to MacPro7,1.
Issue 3: IOPCIConfigurator kIOPCIEnumerationWaitTime 900 hangFixed by disabling Resizable BAR in the BIOS. This was the key fix that finally got past the PCI enumeration stage.
Current status:macOS Sonoma 14 is installed and running on the Gigabyte X870E AORUS Elite WiFi7 with the Ryzen 7 9800X3D and XFX RX 570 as a temporary display GPU.
Still to do:
  • Fix ethernet (RealtekRTL8111 not picking up automatically)
  • Move EFI to internal drive
  • Add RX 6700 XT as the permanent macOS GPU — I understand this requires NootRX.kext as it's not natively supported. Are there any other kexts or config changes needed for the 6700 XT on this platform?
  • Test GPU disable SSDT approach with RX 570 and 6700 XT together before committing to the final RTX 5090 + RX 6700 XT configuration
  • Eventually swap to final GPU configuration (RTX 5090 + RX 6700 XT)
Thanks for the help so far — any advice on the ethernet issue and the 6700 XT configuration would be appreciated!
The RX 6700 XT would be a straight swap for the RX 570 GPU. No other fixes or patches required, just a recent version of NootRX.kext used in place of WhateverGreen.kext.
Don’t use the two kexts at the same time, as they clash during the OS loading process.
You may, or may not need to generate an SSDT-Bridge.aml table, using Corpnewt’s SSDTTime script and your System DSDT.aml table, so the full IOReg Path/Name of the RX 6700 XT is available in macOS. You can check this when you have the RX 6700 XT in the system. The IOReg name is visible on the Hackintool > PCIe tab, look and see if the new dGPU has ‘pci-bridge’ in the IOReg Path/Name.
Reactions: mrt360
Ethernet not working — RTL8125 not visible to macOS
Thanks for the input so far.
Following on from my build thread, I'm having trouble getting ethernet working on my X870E AORUS Elite with 9800X3D running Sonoma.
Hardware:
  • Motherboard: Gigabyte X870E AORUS Elite WiFi7
  • CPU: AMD Ryzen 7 9800X3D
  • GPU: XFX RX 570 4GB (temporary)
  • macOS: Sonoma 14.x
  • OpenCore: 1.0.7
Ethernet controller (confirmed via Windows Device Manager):
  • Realtek PCIe 2.5GBE Family Controller
  • Hardware ID: PCI\VEN_10EC&DEV_8125
  • MAC Address: 10:FF:E0:CC:BB:72
  • Standard RTL8125 — not the BG variant
Symptoms:
  • LucyRTL8125Ethernet.kext loads successfully (confirmed via kextstat)
  • Controller enabled in BIOS, visible and working in Windows
  • No ethernet devices shown in macOS System Information
  • Controller not found in ioreg
What I've tried:
  • Replaced RealtekRTL8111.kext with LucyRTL8125Ethernet.kext v1.2.300
  • With IOMMU disabled — no PCI devices visible in ioreg at all
  • With IOMMU enabled — PCI devices now visible in ioreg but RTL8125 still not enumerated
  • DisableIoMapper: true in config.plist
I've attached the current config.plst and EFI here. Any ideas what I'm missing?
Hi,
I'm still struggling to get onboard Ethernet working. This is where I'm at.
Onboard RTL8125 not enumerated at PCI level — X870E AORUS Elite / 9800X3D / Sonoma
Hardware:
  • macOS: Sonoma 14.x, OpenCore 1.0.7, SMBIOS MacPro7,1
Problem:Onboard Realtek 2.5GbE ethernet (RTL8125) is not being enumerated by macOS at the PCI level. This is also blocking Apple ID/iCloud authentication.
Hardware confirmed working:
  • Controller visible in BIOS: Realtek PCIe 2.5GBE Family Controller
  • Hardware ID (from Windows Device Manager): PCI\VEN_10EC&DEV_8125
  • PCI Slot: 14:00:00
  • Works correctly in Windows
What I've tried:
  • LucyRTL8125Ethernet.kext v1.2.300 installed and loading correctly (confirmed via kextstat)
  • With IOMMU disabled — no PCI devices visible in macOS at all
  • With IOMMU enabled — PCI devices now visible but RTL8125 still not enumerated
  • Ran ioreg -r -c IOPCIDevice | grep ec100000 — no results
  • Ran ioreg -r -c IOPCIDevice -l | grep -A5 "8125" — no results
  • Above 4G Decoding: enabled
  • Resizable BAR: disabled (required to prevent IOPCIConfigurator hang)
Current workaround:Dell WD19S dock connected via USB-C providing 1GbE ethernet through Apple's native AppleUserECM driver. This works for general internet but not for Apple ID authentication.
Question:Why is the RTL8125 not being enumerated at the PCI level even with IOMMU enabled, and what is the fix?
Thanks in advance...!
Another member on this site was able to get their Realtek 2.5Gbe port working by removing the built-in WiFi/BT card. After a lot of investigation it was determined the WiFi card was preventing the Lan controller from working in macOS. You could be suffering with the same issue, as they are both Gigabyte Aorus motherboards.
The LAN port was fixed by doing the following:
  1. Removing an Intel WiFi/BT card that was preventing the Ethernet from working.
  2. Adding LucyRTL8125Ethernet.kext to the /EFI/OC/Kexts folder, with a companion entry for the kext added to the Kernel > Add section of the config.plist.
  3. Using the ResetNvramEntry.efi driver from the OpenCore boot screen/Picker List.
It is not as if you can use the WiFi 7 card in macOS, as there are no drivers for a third party WiFi 7 card in macOS. Itlwm and Airportitlwm.kext only work at WiFi 5 speed, they don't see the additional WiFi 6 or 7 bands.
