Today I updated from OC 0.59 directly to OC 0.65 under Catalina 10.15.7. Everything looks good. Then I OTA upgrade to Big Sur 11.1. Almost everything works except wake up and shut down.
My motherboard is ASUS crosshair viii impact(X570) and CPU is 3900X.
I had a USB map created in Catalina which is fully functional. I also tested every USB port in Big Sur, all works.
The sleep works fine, it took about 8 sec to shut down the screen, stop fan etc. But I can only wake up by pressing the physical power button on the case. When I try to wake it up by USB keyboard or Bluetooth touchpad, the fan/pump start spinning, RGB light on motherboard and keyboard will lit, but the screen won't lit up. After 1 minute or so, the whole machine will go back to sleep mode. However, I can still wake it up by physical power button.
The second problem is: my machine will stuck when I try to shut it down. It's been a problem since Catalina. When I shut it down, the system will logout, screen and RGB light on keyboard will turn off. But the fan/pump will keep working, RGB on motherboard won't go off. And it will just stuck there.
Does anyone have some clues about those problems?
rocessWakeReason Wake reason: Button (0x03)
