Big Sur Beta 10
vk2emp
39
6
Has anyone updated to this version yet? I'm holding off until I have some positive feedback on what needs to be done to ensure a smooth update.
Just updated. No issues so far.
Hi !, i want just updtae from beta 9 to 10 but it won't let me just update, it tells me: "Complete installation necessary for this system" and wants to download the full 12 GB image !!!, something in config.plist ?
Cool - mine went through ok as well. No issues :)
As for yours tura999, I'm not sure why its doing that.
Check the beta 8 --> 9 thread and the beta 7 --> 8 thread, there may be clues in how people got around the 12Gb download there.
Done !, after change secure boot in Misc Security to Disabled !. Now updating ! :D
Hello.I tried to update Big Sur from B9 to B10 ,but beta10 update info didn't appear.
I'm using newest patch (released yesterday) .
And already set secureboot to disabled.
Please help me .
I fix this problem by myself.
Using newest patch.
Enabled SIP
Disabled secureboot
AND
reset NVRAM !!! (This is the method which help me fix this problem)
Updated 10 Beta 10 just fine.
I applied the new AMD Experimental patch.
in Misc --->Security---> Default to Disabled
i added -v to my boot args but my hack just reboots
any additional steps? help :(
Beta 10 won't boot on my machine with SecureBootModel on Default, worked up until now.
Hi anyone using rx5700xt here? My Big Sur beta 10 boots all the time but its always starts with black screen.
I know it because when I press the keyboard, there are sound made for typing (even VoiceOver works CMD+F5)
Funny Part : when I start frustrating and spam typing, the screen glitches and wolaa the screen shows up. But this sometimes can be really hard to "trigger" and will continue to stuck at black screen or blank screen
AMD 3970x --> clover --> Big Sur beta 10 ;)
All up and running here (Version 11.0 Beta 20A5395g).
Initially had a freeze booting up with the apple logo stuck at 90% of the progress bar, and USB devices powering down.
Went closely through my config.plist, updating every aspect - patches, DSDT, settings - and found a few errors / changes compared to the latest 0.62 sample.plist file. For example, somehow my secure boot setting had disappeared from config.plist.
Anyway - anyone having problems it is - as almost always - likely due to a config.plist issue (easier said, than fixed!).
Anyone got slow boot time and lagging dock after update ?
Might be lagg caused by spotlight indexing. Should go back to normal after a couple of hours, depending on how much stuff you have on boot volume.
