KVM display switching issue
Danish297
100
18
AMD 3950X
@Edhawk @Shaneee @leesurone @All
need your help again
My current Setup is as below:
Machine A
Dual-boot system:
Hackintosh (macOS 26.6)
Ubuntu Linux
Machine B
Windows 11 Pro
Hardware
Keyboard, mouse, and monitor are connected through a TESmart KVM switch.
Scenario 1: Windows 11 Pro + Ubuntu
When Machine B (Windows 11 Pro) and Machine A (Ubuntu) are connected through the TESmart KVM, display switching works correctly in both directions. The monitor detects the signal normally after switching.
Scenario 2: Windows 11 Pro + Hackintosh(macOS 26.6)
When Machine B (Windows 11 Pro) and Machine A (Hackintosh/macOS 26.6) are connected through the same TESmart KVM, display switching fails when switching to the Hackintosh. The monitor reports "No Signal" or "Signal Lost".
Troubleshooting Performed
Added the monitor's EDID information in OpenCore using DeviceProperties.
Attached my current config.plist for review.
How are the three systems connected to the KVM, DisplayPort, HDMI or other display connector/cable?
Which KVM switch are you using?
I have two system (machine A and machine B) connected through DisplayPort.
I'm using TESmart DKS402-M24-USBK
Wow, that is one expensive solution. I have dual inputs on my monitor, and use a Mac Master Logitech Keyboard and mouse to switch machines. They can support three different devices using Bluetooth or USB or a combination there of.
great, unfortunately Bluetooth is not working for me :-( what should I change in my configuration to make it work flawless.
The first question is what WIFI/Bluetooth solution are you using? The second is how are you trying to enable it meaning best to zip and upload your EFI.
@leesurone @Edhawk plz check my EFI attached, my mother board Gigabyte Z970 AORUS Master X has Qualcomm wifi-bluetooth what changes need to do to fix EDID to use my KVM.
According to Gigabyte these are the typical WIFI/ Bluetooth cards your motherboard (if it is version 1.0) comes with. Sounds like you have the first one which is fine but none of them are compatible with macOS WIFI hardware limitations. I have never tried to activate Bluetooth using one of the listed modules, I believe it could be made to work but you lack the supporting kexts and config.plist entries in the NVRAM section. I'm not at my desk now but later I can upload what I use on my ASUS Z790 board that has working Bluetooth.
Qualcomm® Wi-Fi 7 QCNCM865 (PCB rev. 1.0)
  • 802.11a, b, g, n, ac, ax, be, supporting 2.4/5/6 GHz carrier frequency bands
  • BLUETOOTH 5.4
  • Support for 11be 320MHz wireless standard
MediaTek Wi-Fi 7 MT7927, RZ738 (PCB rev. 1.1)
  • BLUETOOTH 5.4
Intel® Wi-Fi 7 BE200 (PCB rev. 1.2)
  • BLUETOOTH 5.4
(Actual data rate may vary depending on environment and equipment)
The other issue I see is that Bluetooth requires a proper USB Map and one that correctly identifies the port of the Bluetooth controller. Yours does not and frankly your USB mapping is borked. You have only one USB controller Identified, you probably have two or three, all ports are designated as USB3 and you are well above the 15 port limit macOS tolerates. Until you get that under control Bluetooth is not going to ever work, you are going to have to make a better effort at mapping your ports. This is what Gigabyte says you have on that board:
Chipset:
- 3 x USB Type-C® ports, with USB 3.2 Gen 2x2 support (2 ports on the back panel, 1 port available through the internal USB header)
Chipset+2 USB 3.2 Gen 2 Hubs:
These are typically identified as type 9, possibly 10 for both ports (two per)
- 1 x USB Type-C® port on the back panel, with USB 3.2 Gen 1 support
Same as above
- 7 x USB 3.2 Gen 2 Type-A ports (red) on the back panel
Chipset+2 USB 3.2 Gen 1 Hubs:
These are type 3 for both ports
- 8 x USB 3.2 Gen 1 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
Chipset+USB 2.0 Hub:
Same as above
- 4 x USB 2.0/1.1 ports available through the internal USB headers
These are type 0 if you are using them
I don't think you need to fix your EDID but that is only an opinion. I've never had that be an issue to resolve except for a specific monitor that wouldn't cooperate otherwise. Personally I would use Whatevergreen.kext instead of NootRX. Search for version 1.71d7 that works with Tahoe
InsanelyMac Forum: The specific WhateverGreen 1.7.1d7.kext is one place to find it. Tonymacx86 does as well
One last thing is I don't see the need to be using IOSkywalkFamily.kext and downgrading it in the Kernel Block section of your config.plist. Should not be needed in your configuration.
let me try with below:
1. WhateverGreen 1.7.1d7.kext will remove NootRX
2. will remove IOSkywalkFamily.kext
3. remap USB (can I use Hackintool for this also do I need to remove KVM while re-mapping the USB ?)
Make all those changes to a bootable USB Disk
1. Good
2. Don't forget uncheck the Kernel/ blocked section of your config.plist of IOSkywalkFamily.kext
3. You can try Hackintool, I would try with the XHCIPortLimit quirk enabled and see if that works, if not then without and no kind of port mapping enabled.
To enable bluetooth once USB Port mapping is complete add the three kexts in my EFI in the same order:
BluetoothFixup
IntelBTPatcher
IntelBluetoothFirmware
Then in the config.plist under the NVRAM/ Add section add the two highlighted lines as shown in the screen shot. You can copy from my Config.plist.Untitled.png
1. Good
I made the following changes:
  • Removed NootRX.kext
  • Remapped the USB ports
After applying these changes, I noticed the following issues:
  1. After updating to WhateverGreen 1.7.1d7.kext, the display goes blank immediately after boot. The monitor remains blank for around 30 seconds before the login screen appears.
  2. Still display switching fails when switching to the Hackintosh. The monitor reports "No Signal" or "Signal Lost".
  3. Bluetooth showing but unable to connect any device.
I have attached my new EFI folder. Could you please check and let me know what I might have missed or what needs to be corrected to fix the EDID for my KVM smooth transition from one machine to another.
Your USB Map is still incorrect, please note the following and try again.
How to set USB Port Status
  1. USB2 (0) - Physical USB2 ports on rear I/O plate, these ports always have a Black coloured tang.
  2. USB3 (3) - Physical USB3 ports on rear I/O plate, these ports can have a Red, Blue, Cyan or Yellow coloured tang.
    1. Virtual USB2 ports - served from physical USB3 ports) should be set with the same connector type as the physical port
  3. USB3 (3) - Motherboard Header, usually serving the case front USB3 ports.
    1. Virtual USB2 ports - served from physical USB3 ports) should be set the same as the physical port
  4. Internal (255) - Motherboard USB2 header, this will be any device served from a header port, such as Bluetooth module, case front USB2 ports, case front card reader etc.
    1. Internal connector type should also be used for any Bluetooth USB connection from a built-in M.2 connector (on the Rear I/O plate).
  5. Type-c+sw (9) - Type-C connector on Rear I/O plate, will only show two ports being available,
    1. when the Type-C device is inserted, removed, flipped 180° and reinserted, 1 x Physical Type-C and 1 x virtual USB2 port.
  6. Type-c (10) - Type-C (E) motherboard header, will show four ports being available from a single Type-C connector,
    1. when the Type-C device is inserted, removed, flipped 180° and reinserted, 2 x Type-C and 2 x USB2.
Here are some hints on how to inject your monitors EDID
To inject a custom EDID in OpenCore, use DeviceProperties in your config.plist. Find your GPU's PCI path using gfxutil, convert your EDID binary to base64 or data format, and add it under DeviceProperties -> Add with the property key EDID. [1, 2]
Steps to Inject EDID
    • Find PCI Path: Run gfxutil to find the exact PCI path of your graphics card or display output.
    • Get EDID Data: Dump or generate your EDID binary using tools like Hackintool or FixEDID.
    • Open config.plist: Use a plist editor like OpenCore Configurator or ProperTree.
    • Add Property: Navigate to DeviceProperties -> Add, create a dictionary with your GPU's PCI path, and add a key named EDID of type Data with your EDID byte stream.
    • Save and Reboot: Save your configuration changes and reset NVRAM upon your next boot. [1, 2, 3, 4]
If you meant something else by EEID or need help finding your GPU PCI path, let me know your exact hardware configuration!
Just to be clear because you have a Qualcom Wifi/Bluetooth card Bluetooth may never work in macOS. It may be possible but beyond what I know.
I’m not very good at creating USB maps. Could you please check the attached files and let me know which one is correct— 1 or 2?
Neither but the second one is much closer. USB Type C and USB3 always have two ports, an HS0 port and an SS0 port. Your USB C mapping only has SS0 ports which is incorrect, there is a corresponding H0 to identify and also set as type 9.
My test of a successfully created USB Port Mapping is if the system sleeps and wakes properly multiple times over at least a day. That and of course Bluetooth and other devices connect correctly.
I tried again and completely lost with USB mapping. Sometimes I see ports labeled as UK*, and other times they show up as HS*or SS**, so I’m not sure what any of them mean or which ones I should keep. Could you please help me map my USB ports correctly? I’d really appreciate your guidance.
Mapping USB Ports is always a bit of trial and error and it can get frustrating but asking me to do it for you remotely, without direct access to your machine, raises the level of difficulty to a point I won't commit to. I see you added SSDT-UIAC.aml to your ACPI files, you do not want that enabled for what you are trying to do.
I uploaded your EFI with that and your USBPorts.kext disabled and the XHCIPortLimit Quirk enabled. It should boot and could enable all your USB ports for a temporary solution. It's possible none of your USB Ports will work though as well so make sure you are booting from a USB drive.
The last alternative would be install Sequoia so you can use USBToolbox to map your ports. You can add an APFS volume to the same drive as Tahoe and not hurt anything and its easy to delete later if desired. It give you a better chance at getting Bluetooth working if that is even possible with your Qulacomm card.
