AMD R9 5900x fails to boot Monterey installer
Julian325
Hey guys,
im trying to install MacOS 12 on my computer. But it's not quite working yet :)
Specs:
  • Mainboard: ASRock X570 Phantom Gaming X
  • CPU: AMD R9 5900x
  • GPU: AMD RX6900XT (XTXH) - I want to test a fix after successfully installation: GitHub
  • RAM: G.Skill 4x8GB DDR4 3200MHz
  • Ethernet: Intel L211, Realtek 2.5G 8125
  • WiFi: Intel AX200
  • NVMe: WD-Black SN850 1TB, ADATA SX8200 1TB + 512GB
  • Bootloader: OpenCore 0.8.1
After following Dortania's OpenCore Install Guide I got many error codes when I try to boot the installer. The installer boot in verbose mode, after that I got an black screen and nothing. I linked the EFI-Folder in this post. Maybe there is someone who can help me.
Thanks in advance for help
Try the EFI attached.
It has been revised with a few additional kexts, the SSDT's in the ACPI folder have been replaced with the correct tables.
Some common errors were fixed in the config.plist and it uses the OC GUI boot screen in place of the Picker List.
Julian325
Really nice, thank you!
The installation went smoothly. Now I have the problem that MacOS gets stuck on the "Hello Screen" and "Data&Privacy" and restarts. Do you have any advice for me on how to solve this?
Hi Julian325,
I've looked at your spec and EFI and added in and updated what I believe are missing items compared to my B550 5900X setup. Give it a try.
Julian325
Hi Julian325,
Hi Middleman, thank you for your post :)
Unfortunately, this version didn't work any better, quite the opposite. When I booted for the first time, I got as far as creating an account. But after that MacOS crashed and restarted. After two more attempts MacOS didn't even start anymore with this EFI. Do you have any other ideas?
  • opencore-2022-06-23-033153.txt
  • opencore-2022-06-23-165916.txt
  • opencore-2022-06-23-165946.txt
Hi Julian325,
I think it may have something to do with the fact I'd added in an extra line by mistake (somehow added in a Vega 3 APU driver!). I've cleared up the issue.
So you can try it again. I've also added some XHCI SSDTs for this desktop motherboard.
  • EFI 2.zip
