• AMD High Sierra Kernel
  • Important News and Announcements are found here.
#32363 by Shaneee
Thu Nov 16, 2017 9:49 am
@skadush, I always recommend a clean install for changing to a new OS but if you make a backup first you should be able to update over the Sierra system. I'm in the process of making the official HighSierraAMD image.
skadush liked this
#32365 by skadush
Thu Nov 16, 2017 10:07 am
Shaneee wrote:@skadush, I always recommend a clean install for changing to a new OS but if you make a backup first you should be able to update over the Sierra system. I'm in the process of making the official HighSierraAMD image.
Ooooh noooo.. I have a clone using carbon and made it as a testing ground for any upgrades. Is it riskier to upgrade?
#32398 by Shaneee
Thu Nov 16, 2017 8:10 pm
Not sure I've never actually tried it. If you've got a clone you could test it there though :thumbup:
#32535 by faris3d
Sun Nov 19, 2017 8:13 am
:clap: :clap: :clap: :clap:
We are waiting :thumbup:
Shaneee liked this
#32800 by fatmaddin2000
Tue Nov 21, 2017 11:56 pm
I want to try the recent and new Kernel from Shaneee. How do I change to new one? Is there a script or terminal command I could use?
Thank you!
#32898 by Shaneee
Wed Nov 22, 2017 6:56 pm
fatmaddin2000 wrote:I want to try the recent and new Kernel from Shaneee. How do I change to new one? Is there a script or terminal command I could use?
Thank you!
Replace the current kernel inside System/Library/Kernels then run these two commands in Terminal,
sudo rm -Rf /System/Library/PrelinkedKernels/prelinkedkernel
sudo kextcache -u /
I don't recommend this on your main drive unless you can recover it with the installer post install script for example.
fatmaddin2000 liked this
#33395 by fatmaddin2000
Mon Nov 27, 2017 8:35 pm
Thank you!
sudo kextcache -u /
Thanks! Worked out fine. Getting better scores in Cinebench. Whoooppp!
#33625 by pjhartin
Fri Dec 01, 2017 10:31 am
Can anyone check if virtualisation and hypervisor support is enabled in this kernel? They are needed to run various development tools such as docker.
If you don't have time to install Docker, could you please run these commands in your terminal and share the output:
sysctl -a | grep machdep.cpu.features
This lists the features available on your CPU, I am hoping to see VMX on this list.
sysctl kern.hv_support
This checks for hypervisor support, required for virtualisation tools.
If you could do any of this you would be doing me a huge favour!
#34369 by Egress
Tue Dec 12, 2017 6:15 am
Hi Shanee,
Regarding the Kernels. My 1950x boots the .dmg/USB drive config properly into the Clover command line interface but no matter what I've tried, there is never an OSX installer screen. Is it possible I'm overlooking something quite simple? Thanks.
#34426 by lt-tillermann
Tue Dec 12, 2017 8:07 pm
@pjhartin
I tried both the commands and also installed Docker but it didn't work (Result can be seen in the screenshot).
I would be really happy if there is a solution for this
pjhartin liked this
