• Install and Post Install of HighSierraAMD_V2 Official 10.13.2
  • Tutorials for the installation and post install.
#34981 by Norton287
Thu Dec 21, 2017 1:53 pm
To begin use Transmac to restore the HighSierraAMD_V2.dmg file to a USB drive, the USB drive needs to be at least 8GBs in size. This tutorial by Shaneee covers using Transmac to restore dmg images to USB: http://forum.amd-osx.com/viewtopic.php?f=24&t=1213. Once you have the image restored you want to boot off the USB drive. You want to select HighSierraAMD to begin. If you get a Waiting on Root Device message, move the USB to a different port for a few seconds to see if the install continues. If it does not then keep moving ports until it does.
The installer has a legacy clover install, so if your bios reports a bootable USB with its regular device name and a UEFI one. You want to boot off the regular named USB stick. If you can't boot or it restarts then apply this fix.
You want to mount you USB drives EFI partition following this tutorial: http://forum.amd-osx.com/viewtopic.php?f=24&t=3538
Then copy the below file to USB/EFI/Clover/drivers64UEFI:
https://mega.nz/#!UyYEjRaD!6SMoTJbGXJiI6hfXLs6MR_SPOL2Xzy63c-CQXc-lqs4
Then reboot off USB and you should be ok.
Set your SATA ports to AHCI
Enable USB Legacy support and EHCI handoff
Disable your Serial Port
Enable CSM and UEFI for Hard drives and USB devices
Set Secure Boot to Other OS
Select your USB and hit enter
Highlight Boot macOS from HighSierraAMD and press enter
If this is a NEW install highlight Disk Utility and press Continue
Select your Drive from the left side and click the Partition Button on the right to setup your new partition. You want to format it GUID/Extended Journaled.
Once your new partition is created it will show up on the left side under the drive you created it
Click on Reinstall macOS and click Continue
Click Continue
Click Agree
Click Agree again
Select your drive and click Continue
It will begin copying files for a few minutes and restart
Select your USB and press enter
Select Boot macOS from HighSierraAMD
Click Utilities and Open Terminal
Enter preinstall
Enter your partition name you created earlier
Once it's complete click the Apple Menu and choose Restart
Select your USB drive and hit enter
Select Boot macOS Install from YOURPARTITIONNAME
Soon as it loads the UI it will begin the install, it can take between 20 to 45 minutes depending on your hardware
Once install is finished it will restart
Select your USB drive and press enter
You want to select Boot macOS from HighSierraAMD
Once the UI loads you want to select Terminal from the Utilities menu
If you have an NVIDIA card you want to enter nvweb at the command prompt, then enter your drives name. It will install the NVIDIA Web Drivers.
You want to enter AMD at the prompt
Enter in your partition name you chose earlier
Once its done it will reboot
Follow the tutorial except for the third boot when you boot to your hard drive for the first time. You want to go to Options - Configs and choose the config_injectATI and add your FakeID to Options - Graphics Injector.
This tutorial will help you figure out your fake ID : http://forum.amd-osx.com/viewtopic.php?f=24&t=2976. This should get you to the desktop.
Now follow the tutorial for installing clover, once installed open the EFI/Clover folder with Clover Configurator. Now mount the EFI partition of the USB Installer. Copy the Kexts from EFI/Clover/Kexts/10.13 to your EFI/Clover/Kexts/Other folder. Now copy the configs from EFI/Clover to your EFI/Clover. Now rename config_InjectATI.plist to config.plist and edit it with clover configurator to add your fake ID and reboot without the USB installer plugged in.
Choose Boot macOS from YOURPARTITIONNAME
Choose your country and click Continue
Choose your keyboard and click Continue
Click Continue
Click on No and click Continue
Click Skip
Click Agree
Click Agree again
Enter you Account information for Login
Click Customize
Click Continue
Click Don't Use
Select your Time Zone from the map
Uncheck all and click Continue
Enable or Disable Siri
Finalizing your Install
If you don't have Clover installed here are some tutorials for different install types depending on your hardware and installation choices. You want to do this while booted off the USB to desktop. Also download clover configurator because you're going to need to copy some files between the EFIs as well.
Installing Clover for UEFI
Installing Clover Legacy Bios
Installing Clover to a partition with no EFI
http://forum.amd-osx.com/viewtopic.php? ... 494#p31494
Install Extra drivers for Clover with Clover Configurator
Once you have Clover installed you want to copy the configs and kexts from the USB Installer. Download Clover Configurator and go to the Mount EFI section. Click mount on the USB and Open, click mount on your drive and Open. Now you want to copy USB Installer/EFI/Clover/Kexts/10.13 to Your drive/EFI/Clover/Kexts/Other. Now you want to copy USB Installer/EFI/Clover/*.plist to Your drive/EFI/Clover/*.plist. If you have an NVIDIA card you want to rename NVWeb.plist to config.plist. Radeon users have several options depending on how they have their card working. Most importantly if you have an SSD thats been upgraded to APFS, you want to copy USB Installer/EFI/Clover/driver64UEFI/apfs.efi to Your drive/EFI/Clover/drivers64UEFI.
This topic has 36 replies
