• Use native GPU audio and VoodooHDA for onboard audio.
  • Tutorials for the installation and post install.
#30195 by AlGrey
Sat Oct 21, 2017 7:28 pm
This tutorial will show you how to enable native audio from your GPU (via HDMI or DP) and keep using VoodooHDA for onboard audio (headset jack and microphone input).
Prerequisites:
Have a working GPU
- Webdrivers installed for Nvidia GPUs (Series 7xx and +)
- Lilu.kext + WhateverGreen.kext installed for AMD GPUs (if applicable : http://forum.amd-osx.com/viewtopic.php?f=24&t=2976)
- Have working audio with VoodooHDA.kext. (Check under About this Mac -> System report -> Audio. You should see Manufacturer: Voodoo for at least one device listed ).
1. Locate VoodooHDA.kext in one of the following path:
EFI/CLOVER/kexts/10.xx or Other (xx is your MacOs version) NOTE : use Clover Configurator (Google it) to MOUNT your EFI folder.
System/Library/Extensions/
Library/Extensions/
Note : If you see it in more than one place, keep only one copy under System/Library/Extensions/ or EFI/CLOVER/kexts/10.xx or Other. Delete the others.
2. Right click on VoodooHDA.kext and click on Show Package Contents. Under Contents/, open info.plist with PlistEditorPro
https://www.fatcatsoftware.com/plisteditpro/PlistEditPro.zip
3. Open DPCIManager.
https://nofile.io/f/2qGg9ABJD9m/DPCIManager.zip
Look under the Audio Device. Locate the onboard audio controller (usually Realtek). You will see Realtek xxxxx under Codec Name (xxxxx = ALC885/887/888/889/891/892/1150/Unknown)
In my case the device is 0x10221457. The first 4 digits after 0x are the VendorID. The following 4 digits are the Product ID.
4. Back in PlistEditor Pro, expand IOKitPersonalities and VoodooHDA. Replace IOPCIClassMatch with IOPCIPrimaryMatch.
Replace 0x04020000&0xfffe0000 with 0x(ProductID)(VendorID). In my case 0x14571022.
Save the modifications.
5. If VoodooHDA.kext is under System/Library/Extensions/, rebuild cache by opening KextUtility
http://cvad-mac.narod.ru/files/Kext_Utility.app.v2.6.6.zip
6. Reboot your PC. Enjoy
darkmage1991 liked this
This topic has 11 replies
