• How to Install NidiaWeb drivers El Capitan
  • Tutorials for the installation and post install.
#22682 by vitorlage
Wed Jun 21, 2017 6:52 pm
Installing Nvidia drivers is an easy process, has for ENOCH or CLOVER
Navigate to your HDD/Extra/ folder, inside you’ll see org.chameleon.Boot.plist
Drag and drop it in your Desktop to edit it.
Now open it with Text Edit, you’re going to see this:
<key>Kernel Flags</key>
<string>-v npci=0x2000 nv_disable=1</string>
Now delete nv_disable=1 and write nvda_drv=1
(Don’t forget to leave a space between arguments)
<string>-v npci=0x2000 nvda_drv=1</string>
Now Save, drag and drop into its original place (HDD/Extra), when asked, click Replace.
Now download Nvidia Web drivers for your El Capitan version from here: Nvidia Drivers
If you haven’t yet download Clover Configurator Vibrant edition, do it now.
Then open Clover Configurator and Mount EFI partition
Now goto Boot and check nvda_drv=1
Save
Hope this helps
