• A Simple TransMac Guide
  • Tutorials for the installation and post install.
#15336 by Shaneee
Wed Feb 22, 2017 9:07 pm
For this guide you will obviously need TransMac. You can get a trial of it here,
http://www.acutesystems.com/scrtm.htm
You will also need the DMG you wish to restore. My ones are listed here,
Ok once you've got TransMac installed and the DMG you want to restore right click on the TransMac icon and Run as Administrator.
Once open click on Tools > Settings and open then Disk Drives tab and change the settings to match the image below,
Now that's done we are ready to restore the image. Locate your USB device in the sidebar of TransMac on the left and right click it then choose, Restore With Disk Image.
Now locate the DMG you choose and open it. This will begin to format the USB and start the restore process.
Once complete you will be able to reboot into the new USB installer. Remember to set the USB as the boot device in the BIOS or press the appropriate key to choose a boot device when booting.
This topic has 29 replies
